- Nov 2, 2015
- SE Michigan
- Scott
- Carroll Shelbys Soul Lives Under My GT350 Hood
- Banned
I'm shopping for front and rear sway bars and I have been leaning (pun intended) towards Eibach.
Has anyone used these and can you comment on them or any other brand you guys use. I DO NOT want to use any bar with bolt (clamp on) lateral locks. Thanks.
My car is a 2016 GT350 track pack with the following mods.
Forgeline GA1R open lug 11x19 on all corners
Michelin 305/30ZR19 pilot sport cup 2 on all corners
Front:
-GT350R front springs (240 lbs-in)
-Cortex front sway bar end links
-Cortex front lower control arm bearings
-Vorshlag camber plates
-Cortex bump steer
Rear:
-GT350R rear springs (914 lbs-in)
-Cortex rear sway bar end links
-Cortex rear lower control arm bearings
-Ford performance toe bearing
-Ford performance IRS cradle bushings
-Ford performance differential bushings
-BMR toe links
-Self make vertical links with rod ends
-Self modified stock rear camber links with Ford performance toe bearing and self made delrin bushings
My alignment settings are:
Front:
-2 degrees camber front
0 toe
Rear:
-1.7 degrees camber rear
1/8" toe in
Front:
-Cortex bump steer
Rear:
-BMR toe links
Front:
0 toe
Rear:
1/8" toe in
