What ET or back space
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
for an 18 X9.5 wheel in a square setup
Thanks
NightmareMoon
2016 Mustang GT PP
Do you want a conservative offset, a mostly flush offset or a hella-flush offset?
K4fxd
K4fxd
NKY
More stockish, conservative? I wouldn't mind the tire being closer to the fender but not a priority.
I run 2.25 neg camber on the street -3 on track
NightmareMoon
2016 Mustang GT PP
a 9.5" ET 30 would be flush (its basically equivalent to the common 10" ET35 as far as fit to the fenders goes).
Anything in the ET30-35 range should work really well.
K4fxd
K4fxd
NKY
Thank you.
Rick#7
Hudson FL
2015 GT 50 Years Appearance Package
If you want to be able to rotate them, you'll probably need something around 30-36mm offset. The smaller the offset, the more outward the tire will be, so depending on whether you want the tire more tucked in (higher number ET) or more flush or even some poke (lower number ET), that will determine what precise offset you would go with.
K4fxd
K4fxd
NKY
I'm wanting a stock like square rotatable setup. I don't want any poke.
Would 30 be what I want?
Rick#7
Hudson FL
Yes, if you don't want any poke, stay at 30 or higher ET
