Weird ticking noise at cold start
Amaury
Puerto Rico
na
Morning everyone, I recently started hearing this weird ticking noise every time I cold start the car. Any idea what this could be? The sound start at around 4sc. I will record another video and capture the sound more clearly.
[ame]
Jetset335
Atlanta
Bill
2019 GT350
Amaury, this is exactly the same sound as mine. The question is if this is normal or not. There is a new thread about cam phaser ti-vct noise (11/7). That is what we are hearing, I think.
Fenix
Ohio
2016 GT Premium Shadow Black
I believe that is valve train noise that happens until oil gets pumped to the top of the engine.
Amaury
Amaury
Puerto Rico
na
I changed the oil and sound appeared like 2 months later and just like 500 miles after the oil change
Tash Oh
SoCal
Alex
2016 White Mustang GT
Same thing happens to me and I have no clue why. Also there is a weird rpm fluctuation. Car doesnt idle properly and when I come to a stop in neutral the rpms stay around 1.5k rpm for about a second until they drop. This kind of things happen until the car gets warmed up.
CooterK
Bay Area, CA
2015 Ingot GT PP
This is an exhaust leak. It's coming from the little bracket welded on to the driver side joint, there is a small hole from the welder getting too hot. It requires the dealer to swap out the entire drivers side header and cat, so it's a pain in the ass. I'd throw on your stock exhaust if you have it just to avoid the dealer blaming an aftermarket exhaust install.
Sasuketr
Chicago,IL
2015 Ingot Silver GTPP
If he had an exhaust leak before the cats then wouldn't it trigger a cel?
CooterK
Bay Area, CA
2015 Ingot GT PP
It's after the cats. The header, cat, and flex joint are all one piece. The leak is in the joint where it connects to the cat back.
Amaury
Amaury
Puerto Rico
na
Now that you say that, I noticed by exhaust is not aligned. Passenger side sticks out more than drivers side. The car was perfect the other time I look at the tips while washing the car.
GT Pony
Pacific NW
Might be resonator rattle when cold. Does the noise go away after the car warms up?
Amaury
Amaury
Puerto Rico
na
Well, it goes away after couple of seconds.
Boggus
Cypress
16 Mustang GT PP
Mine sounds like it's coming from the passenger side, front of motor by the compressor
