I'm going to have the dealer check it out because I can reproduce the noise when the engine is fully warmed up.^^ This - but we need to be careful when self-diagnosing these things on the forums. For 10 people who say "I hear it", "it" could be a couple different things.
Actual piston slap might be heard before the engine is warm. If the engine is already warmed up, it's either something else or, if it's piston slap, something is seriously wrong.
Most engines (especially with short piston skirts, which seems like a lot of engines these days) experience that slight rattle sound at part throttle before the engine is warmed up. Some engines you can hear it, some you can't. If it doesn't go away after it's warmed up, have the dealer check it out.
If you want to give it a check before you send it to the dealer - get a stethoscope.
http://www.amazon.com/s/ref=nb_sb_s...tethoscope&sprefix=engine+stethoscope,aps,153
Probably the markings on the driveshaft didn't lined up . How can this pass QA ?For what it's worth, I experienced a vibration that felt like a driveline issue from the moment I picked the car up from the dealership. I originally dismissed it as a wheel imbalance, but it didn't vary with speed and the vibration was felt through the seat. I had the dealer look into it. They ran it on a lift and sent the data to Ford. Turns out the driveshaft was installed "up side down", or 180 degrees out of phase. They fixed it and the car drives much better now.
Not suggesting this is your issue, but for those who read this having experienced a vibration with the car perhaps my experience will help.
Good luck!
