Upper mount notch orientation
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
The upper mount (#11) for the strut assembly has a notch. If the notch is not oriented correctly what can happen? Is there a correct orientation? Thank you, CH
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
The only thing that should happen is your caster will be off by a bit.
CEHollier
CEHollier
Prairieville, La.
Charles
Not sure if you remember my alignment numbers after the springs but they dialed in well.
BmacIL
Enginerd
Naperville, IL
Correction. The studs are all equadistant from the center so no affect.
CEHollier
CEHollier
Prairieville, La.
Charles
One of my patients builds Corvettes from the ground up and is very experienced with suspensions. He came by and listened even laying on the ground as I move/turn the car. He said it is the bushings drivers side.
BmacIL
Enginerd
Naperville, IL
Strut mount bushing or control arm?
CEHollier
CEHollier
Prairieville, La.
Charles
CEHollier
CEHollier
Prairieville, La.
Charles
The lower control arms were changed three months ago.
