Unbelevable slop in drivetrain
1966 Sunbeam Tiger
Orlando, FL
2020 Aston Martin Vantage
While installing steeda springs yesterday I checked the drive shaft. I can turn the driveshaft either direction at least 1/8 turn in either direction with little movement of the wheels. Seems that most of the slop is in the rear diff. Taking it to the Dealership on Wednesday to have it checked. Car has 2500 miles on it. Car sounds like crap with the slop at low speeds.
Enzo
Orlando
Enzo
2018 Mustang GT PP1
that usually tends to be the norm on the manuals.
VinnAY
Kansas City
18 Camaro 1SS/1LE
First time with a manual trans I suspect?
Enzo
Orlando
Enzo
2018 Mustang GT PP1
Driving a manual of various kinds for 35 years now. The slop in this car is not normal.
My experience with American v8 RWD manuals tend to have that slop, my challenger rt had the same thing.
wildcatgoal
@sirboom_photography
TBD
That is normal - well, to be expected and common is better said. It's backlash that's worth worrying about.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2022 F150 PowerBoost
Just had my backlash re adjusted. The spec range is .008"-.012" and they set mine to .008 and it is night and day better.
wildcatgoal
TBD
Did you get this done at dealer? Cost? They won't do it for me under warranty.
phunk
United States
'15 GT-PP
You got the dealer to remove your differential and rebuild it?? Warranty?
Jmeo
You said member ;)
Massachusetts
Jaime
No I had 3.73 gears changed to 3.31 back in February 2015 and I ended up sending my 1/2 shafts back for warranty work so I dropped the diff while I had it all apart and took it back to have them re check it and it was out so they tuned it in for me for zippo.
phunk
United States
'15 GT-PP
Thanks for the details.
Can you describe what needed to be done with your halfshafts? I have some early FRPP halfshafts in my car. I wouldnt mind being aware of anything that needs consideration with them.
Jmeo
You said member ;)
Massachusetts
Jaime
mm2015
Houston
Michael
'15 GT PP
Would what I'm describing below be the backlash you are talking about?
When traveling slowly (~5mph) and I depress the clutch, I can hear shit banging around underneath. It sounds like backlash, because I can use the gas to sort of "relieve" the drivetrain of the torque right before I engage the clutch and I don't hear anything. Also, I can hear the same thing the exact moment the back tires get over a speed bump while going real slow. Exact same noise. Doesn't happen when the front tires go over, only the back.
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
It will sound more obvious when you get on and off the throttle, too.
mm2015
Houston
Michael
'15 GT PP
Maybe I can't hear it that well with the headers during shifting or while driving. But when I'm in the parking garage it's LOUD. Definitely something banging around.
