Tracking: replace front pads = replace rear
TDC
Long Island
So it looks like I have more than enough life on my rear pads so only planning to change front before a weekend of track fun. Good idea or no?
CSL
WA
16 GT350
No problem at all. I blew through two sets of oem fronts and am now running a more aggressive track pad up front. Same original rears with no issues. I have been running my current set up all season and it's working great.
  • Like
Reactions: TDC
Sprintamx
Mid-Atlantic
2016 Shelby GT350
Agreed with CSL: you change pads when necessary. With the OE pads, I'm one set of rears per three sets of fronts. It may be worthwhile, however, the check your wear rates inside to out, and left to right, to see your wear patterns. I have not been getting even wear on the rears, and that could dictate changing the rears even if there's overall a lot of meat left on two or three of the rear pads.
  • Like
Reactions: TDC
TDC
TDC
Long Island
May need to get new rotors and race pads if I can't find the back ordered factory pads. Full weekend HPDE next weekend.
Sprintamx
Mid-Atlantic
2016 Shelby GT350
You don't need to replace the rotors just to change pad compounds: use a scotch brite pad to lightly scour/scuff off the existing pad material, and install the new pads.
  • Like
Reactions: TDC
CSL
WA
16 GT350
Yep...good advice right there. Call Porterfield and grab some Raybestos ST43. Great pad that is versatile and lasts FOREVER.
  • Like
Reactions: TDC
GT350Brakes.com
Northern California
Tony
GT350 TP
To anyone I talk with on here I recommend saving your stock pads and getting a DSUNO/DS1.11 setup or DSUNO all around for the track.
I've done this for all of my previous cars and it works out perfectly.
Since oem is a DS2500 you can switch back and forth with no bedding required.
I was at Thunderhill Raceway this past weekend and my DSUNO/DS1.11 combo is still going strong. I have 4 events on them and have one more left on the fronts and maybe 2 or 3 left on the rears.
  • Like
Reactions: TDC
DocWalt
SE PA
GT350
I was under the impression that the OEM pads were HP1000s?
TDC
TDC
Long Island
Thanks for the help. Was able to find in stock Ferodo DS2500. This forum is a great resource.
