Tire diameter S550
FoMoCo
Illinois
Jeff
2019 Mustang Gt
Any advantage to running a 26” drag radial versus a 28” drag radial at the track? I have a 2019 GT with a 3.55 gear. Would it shave any et?
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
You definitely want a 28”. These aren’t Fox or SN95 days anymore.
FoMoCo
FoMoCo
Illinois
Jeff
2019 Mustang Gt
I understand. I was thinking for a N/A car the 26” may give me a little more gear. I have a 11.20 car, trying for that 10.90 time slip.
Cory S
Bradford, NH
Cory
MT-82 or 10R80?
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
I agree with @Cory S . If you had a stick maybe but the 10 speed gearing is probably really steep in 1st and 2nd gear already. If you have a friend with 26” drag radials maybe you could borrow them for a pass before springing for them and finding out it’s not a good fit.
Cory S
Bradford, NH
Cory
4.70 X 3.55 = 16.7:1 SLR. NOT GOOD.
Jerryinpa
North West Pennsylvania
Jerry
2022 mustang gt
Hi,
I've worked this through on my f150 tires.
For example,
I looked up 235 50 18 overall diameter which is 27.3,
If I were to change to 235 55 18 OD is 28.2
Calculate 27.3 divided by 28.2 whis is equal to 0.9680
Your speedometer will read lower with the 55 series tires. At 60 mph your dash speedometer will read 58.1 and your odometer will accumulate milage lower by the same factor.
The overall vehicle gear ratio is changed by the same factor.
Thanks, Jerry
beefcake
Bethel
2018 Ford Mustang
a 17" wheel with a 305/45/17 street r would be your best friend at the track, if manual then the etr bias ply
let me know if we can help
FoMoCo
FoMoCo
Illinois
Jeff
2019 Mustang Gt
Thanks everyone for your input. Very much appreciated.
Cory S
Bradford, NH
Cory
FoMoCo
FoMoCo
Illinois
Jeff
2019 Mustang Gt
Any negatives of running a bias ply on an automatic car at the drag strip?
beefcake
Bethel
2018 Ford Mustang
doesn't et as well typically "if" radials are working, if the radials aren't holding, then a slick / bias that is bitting and more forgiving will get you better et
