Thinking of buying Steeda Extreme G-Trac K-Brace on my GT 'vert PP1 EU
pardoneo
Spain
Ex-'16 Mustang EcoBaby // Current '16 GT Convertible
Hi guys!
After having installed by my dealer the Ford Performance Strut Brace from the GT350R (and GT350 with Track Package) to mitigate the shaking when our convertibles step on road joints or slight bumps (this is the most distinguished difference I have notice on moving from my Eco Fastback to my new-to-me GT 'vert), I am thinking of also installing the Steeda Extreme G-Trac K-Brace.
https://es.steeda.eu.com/coleccione...ctos/steeda-s550-mustang-extreme-g-trac-brace
Thoughts anyone?
My GT Convertible is a manual trans EU specs (with PP1). Will it be a direct bolt-on? Do I have to remove any brace to be replaced with this one?
P.S: any discount codes for Steeda on the forum? :D
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
In the US, PP convertibles get the additional K-Brace (like a PP coupe), assuming yours has the factory part, I'm not sure how much more, if any, you'd gain going aftermarket.
pardoneo
pardoneo
Spain
Just to double check: do you mean an additional K-Brace behind the belly pan or the black K-Brace included in the upper tower strut?
aleccolin
VA
www.CarClubVT.com
Colin
2016 GT PP
If you can source one, look into the BMR chassis brace. It's working great on my car, and doesn't hang down as low as the Steeda brace, which has been known to take some damage over tall speed bumps or other obstacles in the roadway. I even put the bolts in through the bottom so the only thing hanging down are the heads of the bolts, maybe 1/2" total with the brace flange.
The BMR brace also appears to be a stronger design since it ties into suspension pickup points directly, though it's probably a bit heavier.
https://www.bmrsuspension.com/?page=products&productid=1614&superpro=0
WILDB
Australia
Will
2017 GT convertible Oxford White
+1 for the BMR subframe brace.
I have one fitted to my Australian spec GT convertible, so it will 100% bolt up to your UK car.
This combined with J&M jacking rails, made a noticeable difference to cowl shake.
MikeHTally
North Florida
2015 EcoBoost Mustang, 2020 Explorer Limited
I considered the K-Brace, but decided that the larger RSB, jacking rails and the strut tower brace were enough.
tj@steeda
Timothy
I have the G-Trac Brace on my convertible - lowered & no issues.
Tim_
UK
Lightning blue S550 Coyote convertible
Would you mind going into a bit more detail about what you noticed with the jacking rails and lower brace?
Sigma6
NC
Jay
02ā€™ 360, 06ā€™ GT, 11ā€™ GT500, 15ā€™ 911, 17ā€™ 350
agreed under the circumstances. Iā€™d do LCA & Panhard bar.
Sigma6
NC
Jay
Panhard bar? You know we're talking about an S550 right?
apparently not lol . Maybe I should be logged into multiple forums at once. 2014 called they want my post back :facepalm:
WILDB
Australia
Will
Difficult to describe other than to say that it made a big difference to the car, specifically a notable reduction of scuttle shake, almost eliminated vibration through the steering on rough roads and the body feels stiffer when cornering.
People will probably try to call BS on those remarks, as I did when I read someone else posting it on this forum, but I'm glad to have done the mods, it has made it a better car to drive.
thebaldlatino5.0
Beeville, Texas
Carlos
2017 Ford Mustang GT PP
I've got the Steeda brace coming in tomorrow, and i'm replacing my coilovers with proaction shocks and struts and dual rate springs. So i'm not gonna be too low.
Tim_
UK
Thank you. I think I know where Iā€™m going with the modifications now. Did you install it yourself and if so, was it a straight forward bolt on or are there holes to be drilled and full lift ramps required?
WILDB
Australia
Will
No drilling required and I did find the install to be fairly straightforward, it was a case of bolt on.
The jacking rails can be done on the ground if you are at stock height, however you would find it easier to use a 4 post lift if you are lowered.
I did the subframe brace on the garage floor with jack stands, however it would be easier in the air.
