tj@steeda
Timothy
Rael
Grateful Member
South California
2022 Mach 1
Wish it was CARB-legal. (Sigh.)
I Bleed Ford Blue
North East OHIO
I would be interested if SCT had the transbrake available, but HP is the only one who has it thus far. Part of the reason I chose the 10R80 is for the transbrake so I can drag race it once and a while.
BlkMach10510
2023 Mach 1
Is the up to 22hp with other parts added or is that with just a stock Mach 1? Does it come with a custom tune or do you have to buy the device and then the tune?
ChitownStang
Chicago, North Shore
2021 Mach 1
No Flex tune from what TJ said in other post.
E85 tune would give more than 22hp?
tj@steeda
tj@steeda
Timothy
This was dyno'd at stock. You can buy a single tune or buy the tuning device with a pre-loaded tune.
murick
Prague, Czech Rep.
Richard
2021 Euro Mach 1
Improved horsepower, torque, and throttle response.
What exactly is improved throttle response? I can imagine "improving" it in many different ways, where half of them will be actually making it worse (for me).
BlkMach10510
2023 Mach 1
Was the Mach 1 that was on the dyno a 2021 or a 22-23?
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
When I got a tune, throttle response was changed by having just what it says less pedal needed for same amount of go. And more instantaneous pedal reaction. With an auto, a tune changes shift points and pressures for higher rpm shifting and crisper shifts. Well worth it if you drive an auto. After testing you can get the tuner to reduce or increase the changes to your own driving style. If that's what you're asking.
tj@steeda
tj@steeda
Timothy
2022 Mach 1 was tested.
BlkMach10510
2023 Mach 1
tj@steeda
tj@steeda
Timothy
Good, with or without the hydrocarcbon trap?
Kindly reach out to Matt H. or John M. at our service center in Valdosta, GA. They were intimately involved in tuning and supporting the process. Once all inquiries are addressed, they can also assist in placing an order.
Thank you!
TJ
Rael
Grateful Member
South California
2022 Mach 1
Thank you!
TJ
Hey BlkMach10510, if you receive an answer, could you please share it with us?
Thank you!
noac
Tom
Mustangs
Does this tune/tuner allow the owner to change the tire size to correct the speedometer. Thanks.
