Steeda S550 Mustang NHRA Legal Driveshaft Safety Loop (15-16 All) - Now Available
David@Steeda
United States
www.steeda.com
David
Bolt-on, slammed S197
The S550 Mustang can really put down some serious power, and with the addition of power-adding mods like superchargers, the power being put out can be impressive. The team here at Steeda is proud to introduce our NHRA Legal Driveshaft Safety Loop that will protect your car from driveshaft failure - in any high horsepower application there is the increased risk of u-joint and driveshaft failure.
Steeda S550 Mustang NHRA Legal Driveshaft Safety Loop (15-16 All) | 555-5070: $119.95
Product Benefits
- Safety precaution for driveshaft failure
- Contains driveshaft in case of u-joint failure
- Direct bolt-on installation, lightweight
- NHRA legal construction
- 1/4" thick stamped steel for extreme strength
- Steeda quality, made in the USA
Our Steeda S550 NHRA Legal Driveshaft Safety Loop for your 2015-2016 Mustang GT, EcoBoost or V6 will contain your driveshaft in case of any u-joint driveshaft failure. In the event of a driveshaft failure, our driveshaft loop will keep your driveshaft from dropping down and hitting the ground, keeping you and bystanders around you safe. Protect your investment and prevent any further damage that may occur from a driveshaft failure with the addition of our Steeda NHRA Legal Driveshaft Safety Loop.
Steeda's S550 Driveshaft Safety Loop is a direct bolt-on piece that couldn't be any easier to install. It's made of CNC laser-cut and formed 1/4" stamped steel and has been CNC designed to eliminate stress risers in key areas, giving this piece the ultimate in strength while only requiring two mounting holes! This allows you to save weight and make quicker passes!
