Staggered 275/35R19 & 295/35R19 Pics
Dave2013M3
El Segundo,Ca
2020 Ford Mustang GT Base PP1 6MT Rapid Red
Alright, So I've decide 285/35R19 x 295/35R19 setup on my stock non-hp magnetic wheels.
You all are positive I will not have any clearance issues right?
Can't find exact offset on these
295s on a 10" wheel isn't optimal. I would go 275 up front and 285 out back
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
If he’s running the Conti ECS02 he’ll be good. They run a bit narrower. But in general I agree with you.
ChitownStang
ChitownStang
Chicago, North Shore
2021 Mach 1
Thanks Mags, I just looked at the inside of the wheels and confirmed the offset you sent.
40 front 52.5 rear
Mags, not that I don't trust you but just may run it by the Mach 1 thread for last confirmation opinions
ChitownStang
ChitownStang
2021 Mach 1
Dave2013M3
El Segundo,Ca
Dave, Tire rack says ok on the rim size
I understand, but look at the measured rim width. It's 10.5". It's safe but not optimal. Also a 285 on a 9.5" rim is safe, but not optimal. You want as much sidewall support for a nose heavy car like the Mustang. I wouldn't go above a 275 for the front.
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
275/35/19 ECS 02 up front and 295/35/19 ECS 02 rear on 19x10” front and 19x11” rear Velgen VF5 wheels. Hope that helps.
GrayMater22
Sanford, FL
James
Hey all, anyone have pics of this setup on stock suspension.
Looking to see fender gap compared to stock 255/45/R19 & 275/40R19 setup on PP1 and Mach 1 non-HP
Tiresize.com will give tire diameter, weight, etc for every tire on the market. It is great for checking this type of info.
ChitownStang
ChitownStang
2021 Mach 1
Thanks! Nice looking ride
ChitownStang
ChitownStang
2021 Mach 1
Really, so if I bring this to the track I'll have issues up front? What's not optimal about it when it's within the safe spec? I don't want the 275/35, too much fender gap imo.
Dammit Dave, I almost ordered! lol
CrazyHippie
Michigan
Craig
2023 Mustang GT/CS
If you check your selected tire mfg specs, you may find that a 285 tire is OK on a 9.5 inch rim. That's the case with Continental DWS 06'S - the 285/9.5 combo is OK. The 275 limit for 9.5s is a general rule.
MAGS1
Mark
2022 Mustang GT
Typically a 285 tire will bulge a bit on a 9.5” wheel. Not unsafe, but not optimal from a feel and handling perspective. That said, Conti’s, the ECS/ECS02 in particular, run slightly narrower than say a Michelin PS4S. So you’ll be just fine with 285 Conti’s on the 9.5” wheel. Same for the 295’s on the 10” wheels.
First Stang
2023 Mustang Mach1
Greetings. I’m on the same boat as Chi. Only difference is I have a square wheel setup. I’m between 275/40 vs 285/35 going on 4 19x10’s. I found this article which is very informative. Before pulling the trigger, I’m trying to get calculations on the ‘contact patch’ of the conti ecs2 in the two sizes.
https://motoiq.com/how-to-properly-select-and-size-tires-for-performance/3/
ChitownStang
ChitownStang
2021 Mach 1
Good article!
I ended up with the ECS 275/40 square
Fills the wheel well up nicely!
