Sold: Virginia SOLD
ctandc72
VA
'19 GT 6 speed Base
Used this in my Sync 3 conversion in my '17 Base V6 car. Car is gone. Swapped my Sync 3 into my '19 GT - which does not need the harness, hub or cables. If you have a base 4" Sync setup in a 15-17 Mustang - you need all these to swap to Sync 3 with Carplay.
GPS Antenna. You need this to replace the base GPS. This doesn't give you NAV - simply replaces stock part which won't work with the Sync 3 APIM. Ford OEM media hub - you need this if you want CarPlay to work. Both needed FORD OEM USB cables.
Finally the conversion harness made by Harnesses by Hextall. This interfaces with your stock base 15-17 Mustang wiring so you don't have to repin / cut up your stock harness. Retains back up camera - works great.
Cost me at least $300 for everything. Sell it all for $200 shipped.
1QwkEcoBoost
Sacramento, CA
Shawn
2015 Ecoboost Premium
Pm’d
ctandc72
VA
'19 GT 6 speed Base
Fund received - I'll PM tracking numbers when it ships (probably Monday morning). Thanks.
