DevilDogDoc
So I'll start by saying I have put ARCO fuel in all of my vehicles over the last 20 or so years, in all manner of cars from little Hondas, to Jeeps to BMW's and MBZ and have never had a fueling issue. Since they became Top Tier I felt even more justified in running cheaper fuel that in theory is the same quality.
So since I have had my Ecoboost, I have been running ARCO 91 exclusively and had not had any issues that I could see. In comes the Accessport which gives one the ability to see things that prior were unnoticed, like OAR and ignition retard. I'll explain: Since I got my Adam Tune, I have been carefully watching my parameters and noticed an issue. When cruising down the highway, 6th gear 75-80 MPH, on the slightest of inclines my timing would begin to be pulled back half a degree, a degree, sometimes two. When this would happen the OAR would begin to pull back also, from -1.00 all the way down to -.82 at times. to fight this I would find myself in fifth gear at 80 MPH just to keep the RPM up which would stop this from happening. I had an ignition stumble which I traced back to my new(less than 1000 miles) on them Denso plugs which I got from Tune + when I got my tune, fouling out. So out went those plugs, in went a set of NGK's (one step cooler than stick) and the stumble/misfire is gone. So yesterday I had been thinking of fuel issues and as I had a long trip ahead and needed gas anyway so I put in half a tank of Chevron 91.
Well lo and behold, the issue seems to really have been my fuel. With only a 50/50 mix more or less the OAR is staying solidly at -1.00.The timing pulls a little and advances as it should, but the OAR stays the same. My drive to work is around 90 miles round trip, my run down is mostly downhill and the run back is mostly uphill, albeit a slight grade for most of it. It was in this run back that I would notice my timing being pulled and my OAR dropping like a rock. Well on my run home today I was giving it incrementally more gas in top gear, more than I normally did on the same stretches of road which would make it plummet before, OAR stuck at -1.00, even though the timing did retard here and there, but far less than before.
I knew that OAR was reflective of fuel octane, but the way I was thinking about it it was the timing causing the OAR to drop, but I guess it really is the other way the OAR was causing the timing to pull back.
So I guess the lesson here is that not all 91 octane is the same, even among Top Tier fuels. Here in California, we are already hobbled by 91 so getting the best fuel really seems to make a difference. I'll be filling up with full Chevron 91 on Wednesday so I'll find out how it is, but even on my mix its already leaps and bounds better. On a side note, my mileage went up a good bit from a 24-25 average to 27 as of right now. The 50 cents a gallon in price difference is well worth it to me in both peace of mind against detonation and knowing I'm getting the best cleaning fuels available to me.
And if my mileage continues to stay where it is, well that's just icing on the cake. I'll update in the next few days as I see anymore changes.
