Rear pad click normal ? (video
EF300
The Swamp, Central FL
2017 GT350, 2020 GT500 CFTP
My car has an audible click that comes from all four corners but mostly the rear during light breaking . This is most evident at low speeds. It happens in forward and reverse. I think I have isolated it to brake pad noise. And I can re-create it by jostling the pad with my finger .
I feel like this noise occurred when I first got the car with the stock pads on it. I have since put on Carbotech Low dust pads for Street driving. The noise continues but appears to be slightly louder.
It seems like a little bit loose in the housing. Is this something I should be worried about?
There is a similar noise coming from the Front pads as well but the rear is definitely louder
Should I do something to fix it ? if so how do I fix it?
ty
The Chairman
South TX
‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500 HP
ty
Looks like you are just pushing against the mounting spring? I need to rotate my tires from the last event and will check mine.
EF300
EF300
Yes I am pushing against the spring. But when I put my foot on the brake there is a loud knock from all four corners. Maybe it’s normal, I don’t know
The Chairman
South TX
I just touched my brakes w/o the engine running and all four corners clicked a little. The exhaust valves cycled too. That part always seems a little strange!
Dave2013M3
El Segundo,Ca
2020 Ford Mustang GT Base PP1 6MT Rapid Red
When cold on the PP1 level GT's I get a little click.
The Chairman
South TX
I just got around to rotating my tires and checked: If I push up on the rear pad, it moves just enough to click a little. It’s just the small leeway the mounting spring allows.
But no sound while driving.
