Rear end low rumbling/grinding noise only when slow turning
tmar66
Tom
2019 GT
Only happens in parking lot scenario; low speed, tight turns. Maybe differential, bearings? 2015 v6 auto 69k mi. new tires. It rumbles enough to rattle the dashboard up front and I can really feel it and hear it.
Any ideas?
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
Try adding a bottle of friction modifier in the diff case. Cheap, easy first step unless you want to take it in for a tech to get a look.
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
Any ideas?
Check your rear hub bearings.
tmar66
tmar66
Tom
2019 GT
Now in the shop, hopefully a good answer Saturday. Thanks for the suggestions.
tmar66
tmar66
Tom
2019 GT
The shop thinks it is the differential and a new one he said is around $6000. He wants to verify it with his head technician on Monday to be sure. I'll have to look for alternatives to having them replace it. Maybe a local shop can get one from a pick-n-pull yard. Maybe I can sell it to carmax. I don't drive it that hard, I'm surprised no one else has seemed to have this same issue, at least from what I've seen.
Anthony 05 GT
$6000 is ridiculous. You can buy a good used one for under 1k. Or better yet, have a qualified tech repair yours.
Guard5.0
Indiana
2021 Rapid Red GT500 CFTP
$900 on ebay
RaceHorseV8
Illinois
Ricky
2001 Cobra, 2004 Cobra, 2019 GT
Any update? $6000 is ridiculous! Have the tech check/adjust the gear lash and pinion depth. Then replace the fluid and try it. If it isn't better then rebuild/replace any bad parts. To just junk the whole thing and replace with a new one is a complete copout on the mechanic's part.
Bluemustang
2015 Mustang Base GT
I agree. Maybe take it somewhere else lol. There is no way a differential costs $6000 first of all. That's the cost of a new engine.
tmar66
tmar66
Tom
2019 GT
Yeah, unfortunately I traded it in and got something different. Just don't need that kind of headache now. I do miss it.
aleccesarenriquez
San Antonio, TX
Alec
2017 GT PP
Having this exact same issue now after a diff swap.
Used about 2.5 quarts (little more) of Motorcraft 75w140. No additive.
Any recommendations? I will add some additive this weekend, but want to see if anyone else has encountered this issue.
p6cl
Near Cleveland OH
Ray
2016 Ford Mustang GT Convertible
A friend had an Ecoboost Mustang and all it was to fix was a bottle of friction modifier. When I took it for a test drive I thought it was the power steering system at first. Added friction modifier and that fixed the problem.
New Jersey
David
2017 Ford Mustang Ecoboost
I have the same issue. It makes a rumbling noise in the rear when I turn and go in reverse and turn. Ill try the friction modifier. Keep you posted.
TeeLew
So Cal
Tim
Honestly, that's such a massive load of bullshit that there's no reason to ever speak to this shop again.
You've got a V6, which means a Trac-Lok differential. They're $200 new https://www.summitracing.com/parts/fms-m-4204m/make/ford. The install is ~4 hours. A fully load rear housing with a 3.55 gear and Torsen diff is $1k and the install would be faster. https://www.summitracing.com/parts/fms-m400188355b/make/ford
I would look to bearings first. When a Trac-Loc fails, it goes open. They only make noise if you've done work to tighten it up.
