whatsup62
You will like the 4.10's.....I guess if nothing else now I have an excuse to throw in 4.10s lol
Before races I check over the car pretty thoroughly on jack stands before taking her out. When I have the car on jack stands, rotating either wheel will rotate the driveshaft - the other wheel will remain stationary. I do this every time to check bolt torque on both the half shafts and driveshaft.I will admit I don't think I have ever worked on a torsen differential, but it would not surprise me if when jacked up and load on the driveshaft one wheel could spin without moving the driveshaft. A differential has to allow the wheels to spin at different speeds to allow for cornering.
Is the car in neutral when you do this? When it is in gear and you try this are the wheels locked?Before races I check over the car pretty thoroughly on jack stands before taking her out. When I have the car on jack stands, rotating either wheel will rotate the driveshaft - the other wheel will remain stationary. I do this every time to check bolt torque on both the half shafts and driveshaft.
In neutral. Wheels won't rotate in gear, I'm pretty sure.Is the car in neutral when you do this? When it is in gear and you try this are the wheels locked?
I really don’t want to have to put the car back together in order to figure this out.
I think that's what we need to know. You would think if the torsen was broke there would be metal in the oil, it's not like there are clutches, it is all worm gears..In neutral. Wheels won't rotate in gear, I'm pretty sure.
