rahtid
Anyone else getting this error code with their car? The first time I had this problem was at 2k miles and it turned out to be a bad thermostat since the engine wasn't warming up the way it should.
I got it again at 3.8k miles, but this time the thermostat seems to be fine, and the dealer cannot figure out what's wrong with it, so they sent a ticket to Ford and Ford wants them to check a bunch of things like wire harness etc.
Kind of frustrated right now because first the left rear wheel bearing was bad, then there was a squeal at the front left side of the car due to the oil line bracket being loose (might be related to the recall). I know its not as bad as a bad engine but is anyone else having these silly issues at such low mileage?
I can only imagine it getting worse at higher mileage and more track time.
