Normal pressuresI've never had a car that had as high oil pressure as my GT350. When cold it is 100 PSI. When up to temp at idle, it's at 75 PSI. Any acceleration and it's at 100+.
That's what I thought I was seeing, too. I just got my second oil change at my dealer and it's even lower than when I brought it in! I wanted it changed because I was seeing lower pressures and thought it was shearing down.I've never had a car that had as high oil pressure as my GT350. When cold it is 100 PSI. When up to temp at idle, it's at 75 PSI. Any acceleration and it's at 100+.
Hellll no.That's what I thought I was seeing, too. I just got my second oil change at my dealer and it's even lower than when I brought it in! I wanted it changed because I was seeing lower pressures and thought it was shearing down.
I called the service manager and he swears the correct 5W50 was used. He says he even checked the tech's trash can and found the ten empty bottles.
FYI, he also told me the following came from the shop manual. Normal oil pressure at idle and normal operating temp is 10-15 psi, and at 2000 rpm it is 30-40 psi. Is anyone seeing this low an oil pressure?
I think those listed pressures are for the regular GT and its 5-20 oil. My pressures are more like 40 when warm and idling, and 100 when at higher RPM.That's what I thought I was seeing, too. I just got my second oil change at my dealer and it's even lower than when I brought it in! I wanted it changed because I was seeing lower pressures and thought it was shearing down.
