Oil Filter Threadlock?
cking
17GT350AG/BS-MGW/UPR/ABLIP
Some body mention that spin oil filters have threadlocker on them. So I opened one to check, there is a red tint to the threads, but very very thin.
Is that really a locker?
Does that mean don't prefill the filter, get oil on the threads?
Should we clean the stud on the engine?
SVTinAR
Arkansas
2017 Shelby GT350, 2003 Lightning & ERA FE Cobra
Never heard that before and I'm pretty doubtful of that throry - as red is normally high strength thread locker that often requires the application of heat to soften for removal.
dgc333
MA
15 Mustang Ecoboost Premium
I have never heard or seen any kind of thread locker on an oil filter in my 50 years of wrenching on cars.
AirBusPilot
Austin, Texas
2017 GT350
Yes, it's threadlocker.
I'd still partially fill the filter, and I'd use brake clean on the oil filter block threads.
Fortunately, for me, I have the canister style, so no worries.
The Chairman
South TX
‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500 HP
Ditto. You should put a layer of oil on the seal and the threads before you install an oil filter or you won’t ever get it off.
barstowpo
Witness Protection Prog
Helena, MT
Gordon
2016 DIB GT350 Tech/Track hybrid, 2016 FPRS Car#17
Sure enough, I just went and looked at a filter I have on the shelf. It has a very thin film of red on the threads. Appears to be the same color as red Locktite.
AirBusPilot
Austin, Texas
2017 GT350
Seal, yes, but putting oil on the threads will negate the thread lock.
The Chairman
South TX
Looks like a stain from the cutting oil used when they make the threads? Definitely not enough there to seal anything.
cosmo
Michigan
2005 Mustang GT
It's not a threadlocker in the normal sense like loctite, it's a specially formulated version to resist vibration.
tom185
NC
Tom
2017 GT350
1. Purchase Ford Oil filter Motorcraft part # FL-2069-ST. It was specifically engineered for the 350
2. Spread oil on the seal and install
3. Tuouqe to 16-18 ft/lb Ford spec
4. That filter ain't coming off until you want it to
PS: Swap out the oil drain plug at every change too so you get a fresh new rubber ring to seal to the pan. Ford part number FT4Z-6730-A. At only a few bucks apiece, kind of makes it a no-brainer not to replace it at every change.
http://www.tascaparts.com/oe-ford/ft4z6730a
