arsenalrocks
from my own research it is not a full Synthetic ATF.
XT-10-QLVC
Motorcraft® MERCON® LV is a premium-quality automatic transmission fluid recommended by Ford Motor Company for use in Ford, Lincoln and Mercury vehicles that require MERCON® LV type fluid. This product also provides excellent performance in electronically controlled automatic transmissions. Check Owner Guide and transmission fluid charts for application
Motorcraft® MERCON® LV is manufactured with high-viscosity index, premium-quality, hydroprocessed base oils and specially designed performance additives, which provide excellent shifting characteristics at high and low ambient temperatures and guards against transmission shudder. This fluid has excellent thermal, oxidation and shear stability and good low temperature fluidity. It provides wear protection and inhibits the formation of gum, sludge, lacquer and foam. It also prevents against rust and corrosion. It is dyed red for ease of leak detection
For use in 2012 and forward Torque on Demand transfer cases
Do not use in applications where MERCON® V, MERCON® SP (exceptTorqShift®), Continuously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid or Type F Automatic Transmission Fluid is recommended, or in conventional transfer cases
Refer to the Motorcraft® MERCON® LV product data sheet at the link below for additional information. For MSDS information call 1-800-448-2063
Note: MERCON® LV Automatic Transmission Fluid is available in bulk quantities at substantial savings. Use of bulk oil products is environmentally proactive. Contact your FCSD Aftermarket Account Manager, an approved Motorcraft® Bulk Oil Distributor, or www.Motorcraft.com for details.
found an replacement ATF and it says
http://www.peakauto.com/products/fu...thetic-dexron-vi-mercon-lv-multi-vehicle-atf/
"Resestance to thickening due to high temperature"
that sounds like exactly what I need.
honestly for 2.5 quarts (2.4L) of ATF, I want to use the best stuff possible. my guts is telling me the Motorcraft ATF is far, far away from the best available.
Just wondering, what is the best ATF that is full Synthetic for a tech pack owner like me.
Thanks
XT-10-QLVC
Thanks
