908ssp
I'll never again put a variable spring on my car. They ride wrong. Trying to do two things that just don't go together. 25% increase is fine modest increase and may not over power the stock damping rebound since Ford has increased the damping significantly. I put double on my 2010 and it didn't ride bad at all but the shocks were built for those spring rates and more so the damping was there to control the rebound of the weight after hitting a bump. Lowering a car for looks is fine if that is all you are after. Honestly I don't think the S550 needs it like the S197 having the roof 1.5" lower to start with makes it look a lot better. Spring rates and damping rates need to be considered together if your serious about handling. Ford did an amazing job with the PP.
