Derek@Lethal
- Feb 10, 2015
- Wellington, FL
- Derek
- 2012 Mustang GT 300A w/ Brembo's
Available starting 3/11 from Lethal Performance are the Ford Performance high lift cams for the cross plane crank guys running the 5.2L Voodoo coyote cylinder heads.
Ford Performance 5.2L Coyote High Performance Cams
Now you can take advantage of the new heads on your 5.0L that come standard on the GT350 5.2L motor.
Featuring 14mm lift and 270 degree duration on both intake and exhaust, these cams will really extend the RPM range of the 5.0L that is using the Voodoo heads. These are also the same cams that Ford Performance used on their 5.2L Coyote build that made well over 600 hp naturally aspirated.
Other components that are needed to complete the install are the 5.2L roller finger followers (will be active tomorrow, available 3/31) as well as cam phasers and chains.
If you guys have any other questions about these conversion parts, let us know!
Thanks :cheers:
Thanks :cheers:
