New from Lethal Performance: 1-7/8" x 3" American Racing Headers, X pipe and H pipe!!
Derek@Lethal
Wellington, FL
Derek
2012 Mustang GT 300A w/ Brembo's
Now available from Lethal Performance is new systems from American Racing Headers for your Shelby GT350!
Currently, only "Long" systems are available, and what that means is that this kit includes it's own crossover pipe (available in X or H, catted and off road), some length of tubing and stops at the rear axle to connect to the stock active mufflers.
These headers are built special for the GT350 using .065" wall tubing, thicker than the standard stuff they use on other applications to withstand the heat associated with high revs/power as well as any vibrations the Voodoo motor may produce.
Let us know if you guys are interested in a set of these headers and mid pipe, we'd be glad to assist you! :cheers:
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Any dyno numbers?
CliffClavin
Mid Atlantic
Van down by the river
Any issues with CEL's on these?
To be a bit more descriptive, I'm assuming these require a tune. Does the current tune turn off the rear O2's? If not, has this thrown a CEL?
nastang87xx
Wisconsin
2016 GT350 Track Pack
Removing factory cats will ALWAYS throw a CEL for catalyst under efficiency, even with high flows. The only time it might not is with Kook's Green Cats and they're hella expensive.
xt6wagon
WA
2016 GT350 base triple yellow
So, ceramic coating?
optional resonators?
G-FORCE
PATRIOT
Knox Tn.
Doug
MANY
Any sound clips with H pipe vs X? Cat-less X on my 09 WHIPPLE GT500 is way too raspy. It also lost low end torque by the butt-o-meter.
