Need suspension advice
bigwill90
Roberta, GA
Will
Ok made three track pass last night on every pass when the car shifts it dips and slightly goes left .. I’m thinking maybe check alinement or need to buy bmr lower control arm bushings
2018 GT A10
Lund E85 tune
F14 drag pack
BMR C lockout
BMR Vert links
BMR irs bushing
Adj shocks
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
2018 GT A10
Lund E85 tune
F14 drag pack
BMR C lockout
BMR Vert links
BMR irs bushing
Adj shocks
Check alignment and also check to see if your cradle is centered (measurable difference between left and right wheels to quarter panel)
bigwill90
bigwill90
Roberta, GA
Will
If the cradle is centered what would be the next step
BmacIL
Enginerd
Naperville, IL
Alignment. If your thrust angle is not 0.00 you may feel what you're feeling. You want about 0.10 deg of toe per side in the rear. Also another less likely but possible cause is tires if you've recently changed/rotated them.
Wile-E Coyote
Canada
2015 race red GT PP
mine goes left super hard when i stomp on it too. I was contemplating if i had broken a half shaft. will check my centering as my thrust angle is 0 and i have about .1 of toe.
