Need help to tune 2019 GT350 (Whipple) after engine swap
Tenek
IL
GT350
Hi everyone,
I need help with my supercharged (with Whipple) 2019 GT350. I got it recently with the supercharger already installed. I took it to a mechanic for diagnostics and a Lund Racing tune. The car passed the 93 octane tune successfully, but unfortunately, the engine blew out on the E85 tune (rod through block). Luckily, the mechanic's insurance stepped in and covered the engine swap. So, they swapped the engine and moved the supercharger and its components to the new engine. They also applied the 93 octane tune from the old engine.
I took the car back home yesterday, and by the time I got home, the check engine light came on. The mechanic said it's a "tuning thing." I don't really know what's going on, but my guess is that the new engine swap introduced a lot of offsets, making the previous tune no longer suitable. I can't get a proper new tune before I break in the engine. It's showing "system too lean" in two banks and "misfire on startup." Additionally, I've noticed quite strong bucking at RPMs lower than 2k. I don't want to damage the new engine, so I will not drive the car until I have a plan. Maybe the Lund Racing folks can help me with a mild tune for the break-in period, and we can re-tune it later when the engine is ready. Alternatively, I could find a professional in the Chicago area and carefully take the car there for proper treatment.
Thank you for any advice and recommendations.
PS: Creating a new thread for more attention. My original posts are here: https://www.mustang6g.com/forums/threads/questioning-gen-2-voodoo-reliability.195529/post-4037979
2019 Shelby GT350
  • Cold Air Kit: Whipple 123mm
  • Throttle Body: Whipple 132mm Eliptical
  • Injectors: ID1300x2 with Dual BAP
  • Power Adder: Whipple 3.0 Front Feed
  • Cams: Stock Cams
  • Gears: 3.73
  • Lund Tuning Device Type: HPT MPVI3
engineermike
La
2018 GTPP A10
A new engine didn’t make it run lean. It is possible a (diy) crank relearn can help with the misfire code. There’s no such thing as a breakin tune. If the maf, fuel pressure, and injectors are the same and the tune didn’t change then it should work unless there’s some mechanical issue like a vacuum leak, dirty maf,, fuel pump failure, etc.
robvas
MI
I'd ship that car to the nearest GOOD mustang shop that can disgnose and tune it, with experience, vs what sounds like some rando 'mechanic'
Tenek
IL
GT350
Hey everyone, any recommendations for good Mustang shops around the Chicago area? I'm talking to Wengerd right now and hope he can help me with tuning and any extra work if needed to make the car perfect.
Also, my friend recommended https://fluidmotorunion.com, but I didn't find anyone who mentioned them on the forum. At this point, I would like to take my car to a facility where it can be properly fixed and tuned.
larr12
Alberto
2020 Mustang PP1
J17GT
IL
2017 Mustang GT PP
Mike Post @ DynoTuneMP is top notch. His shop is in Hampshire. A bit of a ride depending where you are in the Chicago area, but worth it If you need a trustworthy shop.
https://www.facebook.com/DynotuneMP
https://www.dynotunemp.com/
Tenek
IL
GT350
I talked to Mike Post, and he is booked until late July btw. He said it's not tune-related and thinks it might be a vacuum leak or an exhaust leak somewhere, which is pretty much what engineermike said above. I'm talking back to the original shop, and they should fix that under the insurance claim opened for the engine swap.
