Nannies
stageron
Bellmore, NY
Ronnie
2021 Mach 1 M2559, Lexus NX300
Please tell me there’s a way to turn off active braking where it doesn’t default to on every time I start the car.
ChitownStang
Chicago, North Shore
2021 Mach 1
I found that out as well. turned it off when I got the car then had it do that big brother shit to me when getting too close to another car, starts blinking at me when I'm doing 80 passing, crash warning! I thought it was going to slam brakes on me but didn't fortunately
Tshenberg
Independence KY
Thomas
2021 Mach 1 Chassis M1908
really? i have not had that happen at all to me. Only on surface streets when get a little too close when accelerating does it warn me
stageron
stageron
Bellmore, NY
Ronnie
You can adjust the sensitivity to low which helps but I can’t believe I can’t disable it permanently. It’s like my Jeep with that damn start stop bullshit, have to disable it every time I start the car.
Atlas1
Everett, WA
There’s no way to turn it off completely even at a track?
Wraith272
Snohomish, WA
S550
I believe putting the car in Track Mode disables it, but since the car defaults to Normal Mode every time you start the car, you'll have to make the change every time you drive
stageron
stageron
Bellmore, NY
Ronnie
You can go into the car settings and disable it but it will default to on the next time you start the car.
cactus_kid
Big Bend Country, TX
Michael
'21 GT (see sig)
Simple solution ......................... Don't use cruise control !
shogun32
Northern VA
SOmeone will (has?) figure out a ForScan item for this. Or just don't buy '(un)safe and stupid' next time?
stageron
stageron
Bellmore, NY
Ronnie
Cruise control has nothing to do with it, talking about the pre collision active braking.
stageron
stageron
Bellmore, NY
Ronnie
Page 204 in the manual,
You can switch active braking off using the information display controls. See Information Displays (page 99).
Note: Active braking turns on every time you switch your vehicle on.
CRAP!
ChitownStang
2021 Mach 1
I bought a module that stays in the OBD port of the wife’s grand Cherokee to keep the auto start off and restart in the same modes I shut the car off with.
Hopefully someone makes something one day for Ford
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Can you unplug the proximity sensor?
