MMR S550 / S650 Rear Differential Oil Cooler Kit for 2015-24 Mustang GT
Mod Mustang Racing
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
If you have ever taken your S550 / S650 Mustang GT to an open Track Day, HPDE, Autocross or Time Trial you have likely seen the dreaded Differential warning light turn on. Overheating is VERY common and this is why the GT350 models came standard with a differential cooler. Not to worry, MMR has engineered and tested our differential kit to handle all the challenges of racing and we guarantee our kit to offer the lowest temps and the highest performance!
Features:
Hi Efficiency Heat exchanger and Fan
Hi Temperature and Pressure Motorsports Approved Hose and Fittings.
Stainless Steel Mounting hardware to prevent rust
Thermostatic Relay, temp sensor and Wiring
High Quality Tilton motorsports oil pump
Mounts simply and cleanly under spare tire well.
Fits:
All 2015-2024 S550 Ecoboost, V6 and GT Applications
Also great for 2016 GT350 applications that were not originally equipped with the diff. cooler
Order now!! $699!! https://www.modularmotorsportsracin...n_page=product_info&cPath=87&products_id=1420
Mod Mustang Racing
Mod Mustang Racing
Mod Mustang Racing
Mod Mustang Racing
Mod Mustang Racing
Mod Mustang Racing
CrazyMustang
los angeles
CrazyMustang
2015 Mustang gt auto
Could you post some detailed pictures of installation here? I received my standard kit yesterday but cannot figure out how to connect the wires, there is no install manual. And it seems that there is no connector to the drain and fill hole position in standard kit.
Mod Mustang Racing
Mod Mustang Racing
For wiring, the relay kit with temp sensor includes a simple schematic, in regards to the fill and drain connectors on the std kit, you simply screw in the sensor block provided into the drain hole, for the return we have provided a 1/2npt to -8 fitting , if you are missing something please call so that we can get it resolved.
Bridgie
Raleigh, North Carolina
2015 GT fastback. PP, 50th trim, Black
Any forum discount on this..? :)
Mod Mustang Racing
Mod Mustang Racing
Mod Mustang Racing
Mod Mustang Racing
Jupiter Sean
Jupiter Florida
Sean
2017 GT/CS Blk
Black Friday deals?!
