Glenn G
- Jul 3, 2015
- Kaiserslautern, Germany
- Glenn
- 15 DIB 6MT base Ecoboost
Last night I decided to do a datalog of the performance of my MAP intercooler under the most stressful conditions it sees.
A 3rd gear pull is just over way too fast for good data, the CATs barely getting 12 degrees above ambient and it can be a bit dangerous dropping to 50mph on an unlimited autobahn where slow traffic does around 80.
This a a 5th gear pull from ~3000 to 6000 rpm or ~75 to 139mph. Do not try this outside of Germany, you'll likely be arrested
Ambient temperature was 72 degrees with 90% humidity, (got to over 100% near the end because it started raining.)
max boost targetwas ~24psi which begins slowly dropping off from 5300 rpm down to 22.6 at 6000 rpm as the turbo falls out of it's efficiency band.
The Charge air temps started at 82.7 F, after about 35 minutes of hard driving or ~11 degrees above ambient, which is very good! temps drop slightly before climbing to a max of 111 (39 F above ambient) at my shift to 6th, at this point the temps settle and dos not rise as I keep my foot planted to ~145 mph where I had to let off due to traffic and the fact that it had started absolutely pouring rain ending my fun for the night.
