ATLalien
Just thought I would share my opinions on my new Michelin Pilot Super Sports. I've had the tires installed for about 3 weeks now and we haven't had any rain during that time, so unfortunately I don't have any feedback on the wet performance which is one of the main reasons I chose these tires. If folks are interested, I'll be glad to post a wet weather update.
Car: 2015 GT PP, Bone Stock. I got only 10K miles out of the stock Pzero Summers.
- Requirements: I wanted a tire that was at least as sticky on dry surfaces as the stock Pzeros, but with better wet performance, and a higher wear rating. Living in GA and having a second vehicle to handle what little ice/snow we may get, I had no need of an all season tire.
- Tires considered: After briefly considering going back to the stock rubber, I narrowed it down to two tires which I don't see cross shopped very often (likely because of their difference in price):
- BFG Comp Sport 2 (Max Summer): These tires were very highly rated for dry traction and especially wet performance. They are significantly cheaper, and have a higher wear rating (UTQG-340). However, I found very little test data except what came out of BFG sponsored events, which compared to lower tier performance tires.
- MPSS: Universally the highest rated performance tire based on everything I saw. Wet & dry performance had very good test results in every review I could find from multiple different sources. Tons of test data on these tires. Lower UTQG, at 300, than the BFGs but higher than the Pzeros (220).
I probably would've been pleased with the BFG's and saved some $ to boot, but with this car I didn't want to have any regrets just to save money. Due to that and the overwhelming positive test data, I chose the MPSS.
- Daily Commute: I immediately noticed the ride quality and smoothness were improved over what I remembered from when the Pzeros were new. Any road imperfects were a little smoother. Steering is more responsive and precise as well. The biggest improvement I noticed here was traction on hard launches from a stoplight. Even when the Pzeros were new, they would break lose much sooner. With the MPSS, the most I've produced is a quick chirp and the car just goes. Granted, being on public roads, I'm only launching at maybe 3500 RPM or so, which is about as much as I'd give the Pzeros when new. Also in the kinds of spirited driving I'm comfortable doing on public roads, I've yet to break traction between gears where this would routinely happen on the Pzeros. Don't get me wrong, this car has enough power to break any street tire loose from a dead stop, 1-2 shift, and 2-3 shift; it's just more difficult to lose traction on the MPSS's.
- First "spirited" mountain drive: I actually thought the stock Pzeros were pretty good in this environment when new. The differences I observed below were not huge, but were noticeable improvements.
- Initial bite/grip: A bit more confidence inspiring is the best way I can describe it. Maybe a little less body roll, no sliding or squealing on initial entry into a hard turn. I hit the first turn much faster than I planned and the turn was much deeper than anticipated (Gmeter register .84 here). I didn't hit the brake, just let off the throttle and the car carried it's momentum through the turn with no drama.
- Corner Exit: Another area where I would chirp the Pzeros often, exit in 3rd gear and jumping back on the throttle fairly hard on exit. No drama from the MPSS, just point and shoot action.
- Steering/Transitions: More precision on quick transition turns left to right, and back. Noticeably less body roll.
