15Pony
- Dec 16, 2014
- Jackson, MS
- Bruce
- 2015 Mustang V6
As far as I can recall I did not notice this last winter. If I start the car on a cold morning (here in the south the weather isn't that cold - yet - so I'm talking about below 50 degrees) and back out of a space turning, then drive off and turn, I hear it. It sounds like its coming from the rear. I can only describe it as a low pitched sound like a grinding, sort of like if you try to drive on an almost flat tire. In fact, the first time I heard it I actually thought I was getting a flat. All the tires have at least 31 though. It **only** happens if I make a turn in forward or reverse, AND, after maybe 2 or 3 turns and/or a couple minutes of driving it is gone. It does not need until the engine or trans fluid warms up to normal temp, just driving down the block and then its gone. I never hear it when the car is hot and I do not have the infamous driveline vibration.
Could it be the diff, or the axle joints, or ? Anybody else have this?
I'm assuming this will get worse the lower the temperature goes.
