Khyber
it's a hard parked life
- Nov 28, 2014
- Lexington/Myrtle Beach, SC
- Landon
- 2015 GT PP CO
This is my first ever bag setup but wanted to give this tip.
Sooo long story short I had my bags on for about 6 months now...which has not been the most painless mod ever. I swear it's always something especially with leaks and them shitty connections no matter how perfect the lines are cut. anyways...
After not driving the car for about a week I came home to find my tank was empty... hmm.. I was like that's strange...I checked everything, no leaks at the tank. So I filled it back up.
Next day the chain of problems began. I was popping 30amp fuses all of the sudden. In which the arcing destroyed the fuse box the air ride came with so I replaced the fuse box holder. I was still popping fuses after a couple of days.
So I started noticing during this time that the tank was leaking oddly again...Every time the tank leaked and compressor would try to kick on, pop goes the fuse. So after my uncle and I chasing this problem down for over a month. We discovered that the compressor was kicking and drawing 34 amps at random times. We were like, is the wire to small that came with the kit? There is no way! Every car has this same gauge in just about every kit and people run two compressors!
Anyways what it apparently ended up being was the check valve from the compressor on the tank. The air was going back to the compressor causing it to draw more power.
So I replaced the check valve with this one. https://www.bagriders.com/smc-compressor-check-valve.html
After I got the factory check valve off, sure enough you could blow through each end and it was extremely hard to blow through inlet side. With the new SMC check valve, air freely flows through the inlet side and it's been A LOT LESS stress on the compressor and I notice it fills faster.
No more fuses blown so far and it's been about 3 weeks! No tank leaks... What a relief. Nothing like not being able to drive your car because it fallen and it can't get up like an old man.
now back to chasing this front left leak :frusty::frusty::frusty:
