- Dec 20, 2014
- Lake Worth, FL
- Website
- www.uprproducts.com
- 15 GT
I just wanted to go over the install of the ROUSH front lower grille, splitter, and Aero pockets on the 2018 Mustang. This kit will fit any 18 model front bumper (non shelby.) The directions from ROUSH for the splitter and grille are very straight forward and easy to do.
If you are like me, videos always help. Bill from CJ Pony parts released a video of this install as well. I did watch it and it had some helpful tips and with a good visionual persective of this.
Here are the install videos for installing it how ROUSH recommends.
Bumper install found here: [ame]
Aero Scoops install video found here: [ame]
Now..........
I want to add a couple things I did different to help it fit with the stock belly pan (it's designed for a PP) and with NO DRILLING into the bumper for the Aero scoops.
I'm not going to go over the removal of the bumper because it is pretty straight forward and nothing special on it. But once you take it off, you will want to remove the stock belly pan then the stock front splitter.
Once you have these off, pop off the grille bracket than the bottom stock grille. (be careful you do not break the tabs) Once you have that off, take the ROUSH lower grille and from the outside, slide it in till it sits in place and push the clips back on. Because the bumper is a poly material, it can flex which will allow you to have wiggle room and the grille fits. We found this easier to do and fell right into place.
Aftet this is on, install the ROUSH splitter with the provided hardware and bolts. You will press / clip it on. With one person holding, have another person installing the bolts on the backside.
Now.... once you have that all done. You can do the Aero scoops. With this... The directions make you drill 8 holes in the front bumper. Me though, always wants to have the option of removing if need be. So myself and a couple others figured out a way You are going to need to cut the 3 tabs off the side of the scoop and the bolt hole on the front of it.
Make sure its flush with the rest of the scoop so it installs straight. Once you have done this. Use the double sided tape they provided as per the instructions but then add more around every part that will connect to the car.
(the photo only has a couple strips on it and I would do a couple test runs to see what parts contact the bumper so you have enough.
Their will be a triangle bracket with this kit which is for the backside of the scoop. This bracket you will use like the ROUSH instructions say. You will drill a hole into the factory plastic as shown below
Then attach the bracket to the scoop. Make sure to do like 50 dry-runs to make sure everything is straight.
Once you screw the backet onto the back side, make sure everything still lines up, check again, then check again. Once you have it in place, remove the red tape backing and push firmly onto the bumper. (make sure its not cold so the tape can stick) Then boom.. Scoop is installed.
NEXT.........
When installing the front bumper back on. You will reuse all the factory holes on the belly pan except the 2 that are to the outside by the fender. You will need to make a braket, zip tie, or something to attach them.
The front lip has side panels that go up the fender. YOu do have to drill one hole for the top of it but the bottom 2 use the factory push-pin holes. This is straight forward with installing per ROUSH and the CJ Pony video. If you are lowered or a large tire, it will hit this panel on bumps or hard turns. As shown here:
But this is a simple fix. All you have to do is trim the panel down as shown below.
You will cut just a small section off of it on each side. As shown here
Once you have this trimmed, go ahead an install them per the ROUSH instructions and you are good to go.
Final product:
The point of this was to just show a easier way to install the front bumper aero scoops and to trim the side panels so they do not rub. If you follow the directions ROUSH gives you or the CJ video, everything can be installed no problem.
Another note.. ROUSH includes a bracket that mounts behind the bumper that will attach the frame to the middle of the front bumper to give it extra stability. This is like the rods people put on the outside with a splitter. This is heavy duty and I commend them 100% for this! :cheers:
Thanks for taking the time to read this. But remember... the ROUSH scoops can be installed without drilling into the bumper itself.
Now..........
NEXT.........
Final product:
