HUGE PROBLEM SOLVED BY JLT Performance! (Rock Blocker)
Status
Not open for further replies.
Vinny@JLTPerformance
Chesapeake, VA
2015 Mustang GT
Well maybe not that huge of a problem :D.
Do your GT350 Side skirts look like these after a normal drive? Semi-exaggerated
One of the very first things that was noticed after being around a few new GT350's was the rocks the side skirts collected under normal driving. We spent countless sleepless nights thinking of a solution for this MAJOR problem. After a Monday night of no sleep, we got it!
Ok Maybe this is more realistic.
We designed these foam inserts that simple tuck into the open area of the side skirt to keep this area clean of road debris. These have been tested to 225 MPH on a stationary dyno :thumbsup:. We would recommend removing them for track days and extended high speed driving. They have been road tested to 100+ MPH, on a closed course. Do not attempt!
Whats included: (2) JLT Rock blockers and Peace of mind and ability to sleep at night known rocks aren't on your side skirts. :cheers:
Discount code for this forum is MF6G5% and can be used at checkout.
Purchase here: http://jlttruecoldair.com/ZenCart/i...ct_info&cPath=524_525_510_543&products_id=925
OMGPonies
SF Bay Area
2016 Track Pack
Definitely a clean solution and easily reversible, so no harm done using it. But just thinking that Ford left that opening for a reason? It looks well placed to help with airflow attachment coming off the tire and down the side skirt area.
Chesapeake, VA
2015 Mustang GT
Are there some aerodynamic advantages? I'm sure.
ITLRUN
HiPo Joe
Adairsville, GA
Joe
2017 GT350R HR186
"Sticky" tires will make this even more of a problem. You will even find rocks in your tail pipe tips. Ford even calls the holes, "pebble drains".
TripleYellow
TX
16 Shelby GT350
Is it possible to purchase from you without having to create an account? I didn't see a way to do that. Thanks
Chesapeake, VA
2015 Mustang GT
You can call to order if don't wish to create the account.
04Terminator
Humboldt County CA
Cindy
GT350 (sold); 04 Cobra (sold)
Ordering immediately!
Bender
SE PA
17 LB GT350R HR909, 22 AB GT500 CFTP
Just ordered mine
travis1978
North Dakota
Travis
2016 GT350 Magnetic with Tech package
Just ordered a set. Great job guys. Much appreciated!
ihc95
2018 GTPP A10 401A
This completely defeats the aerodynamic advantage of those side skirts. Just saying.
Bender
SE PA
There is no aerodynamic advantage lost on street use. I won't loose sleep over it. Get to the track and throw them in a bag and put them in the console or glove box. Problem solved
stanglife
Jeff
1993 Coyote Coupe
I think this is a horrible product. I hate it when I get rock blocked...they've always got some smarty pants friend who knows best...errr, never mind.
Chesapeake, VA
2015 Mustang GT
Lol as someone who has a lot of track time under his belt. Even IF this effected the aerodynamics of the vehicle, if you were a good enough driver to notice it...you should be in one of the professional racing series.
The ROCK BLOCKER is simply something to keep you from bending over at car's and coffee to brush the rocks out of the side skirts after the drive there.
Status
