How to tie in fuel pressure sensor GT350?
fosgateZ
Phoenix, AZ
Nick
2019 GT350
Waiting on my procharger kit to come in and doing all my research. I'd like to install a fuel pressure gauge as well as boost, unless that can be turned on with Forscan. I don't see a schrader valve anywhere on the rails. I do see Nitrous Express has an adapter but it doesn't show the GT350 as compatible. The fuel lines look the same on a 5.0 . I had found a post using this adapter with the 5.0 as shown in this post:
https://www.mustang6g.com/forums/threads/fuel-pressure-and-boost-gauge-install.23211/
Can anyone confirm the adapter will work or what you did to tie into the fuel system? I don't want to cut anything.
Thank you
galaxy
St Louis
'17 GT350
Aftermarket fuel rails. They have plenty of ports/options and look soo much better.
fosgateZ
Phoenix, AZ
Nick
2019 GT350
Thanks those are beautiful but I'm tapping out on annual present to myself for "Surviving the Summer " working outside here in Phoenix . Fuel system will be next year. Lethal says they don't see why that adapter wouldn't work. Hoping someone else can chime in.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
On a GT350 there should be a pressure sensor on the driver side fuel rail. Just get a y adapter and use that port.
