How-to: Paint your coolant reservoir tank
papinist
The Italian Pony
Tuscany, Italy
Stefano
Mustang EcoBoost MT Race Red EURO - NO MORE
Hey guys,
almost every Mustang owners hate that big white football-shape tank that Ford placed right in front of you when opening the hood.
Many replaced it with an aftermarket model, but actually this is a part that is doing its job perfectly so I can't see why pay 150-200 bucks for replacing it.
I've seen also some plastic cover, but at some crazy price (like 80 usd!), and still it's not a perfect solution since the bottom part remains uncovered.
Someone has the right idea to simply use plasti-dip to black it out and frankly I think it's a great idea! Searching the forum I've found many that already did it but a tutorial is missing, so during my mod I took some pictures for helping others :)
I have used plasti-dip but actually you can also do this mod with regular paint: when seeing the result, there is no reason why you want to revert back to stock in future. So if you haven't plasti-dip or it's too expensive (I already have an half can but shops does not have it here, and online you need about 20 eur + shipping), use high temp spray paint and you're done.
REMEMBER TO DO THIS WHEN YOUR CAR IS SITTING DOWN FOR A WHILE, OR YOU'LL BE HIT BY HOT COOLANT AND IT WON'T BE FUN :frusty:
This is the initial situation:
Start by removing the cap and loosen the two clamps that are holding the two side hoses. This is better accomplished by using nose pliers. Squeeze a bit the two hoses before removing to allow any extra coolant to flow in the tank. To remove the hoses easily, twist them forward and back before trying to pull them apart.
Set apart the two pipes keeping the one in the back higher than the coolant tank or coolant will spill from it. I also used a channel lock plier to keep the hose shut.
Remove the two 10mm front bolts and place some masking tape on the upper thread and on the two side plugs. At this point you can raise the tank a bit with the help of something (I used two plants poles)
Place some used towels or kitchen paper under the tank bottom to avoid spraying something else. Cut open a trash bag and make a center hole where you will place the tank to cover most of the engine components.
Detail of the masking job
Now the key feature: since you still want to know if the coolant is at the right level, place a strip of tape in the back of the tank. You can place wherever you want on the back: it will be hidden to direct view but you can still check the level easily. I found a 1cm wide electrical tape that is perfect for this goal.
Now it's all ready to start
Start with the first coat, you don't need to cover it up perfectly since it's only the first coat. Wait about 15 minutes between coats and if you have enough spray, the best result should be obtained with 5 plasti-dip coats (maybe 3 is enough with paint). I did only three coats because my plasti-dip can was at about half and it finished after the third coat :headbonk:
Don't forget to spray the bottom part.
First (or second?) coat
Third coat
Wait until plasti-dip\paint is dry. Now we need to remove the tape we used on the back, to reveal the window you will use to check the coolant level.
Before pulling it out, follow the tape's edge with a knife to avoid peeling back plasti-dip with the tape (ask me how I know)
You have almost finished: remove the masking tape (pay attention here too to not peel off plasti-dip)
Remove the trash bag, place the tank at its place, put back the two bolts, reconnect the tubes, tighten the clamps and put back the cap.
End result:
Looking at the back you can easily check the coolant level (not so easily in this picture, with tangent sunlight!)
Direct comparison before\after
waaaaayyy better and with a negligible expense!
:cheers:
Notes
Moustang
Belgium
BLACK S550 EB/AT/PP/EU
Nice one Papinist! Hydro-dip might be cool as well, but then you need to empty the tank first and use a white base coat.
T-S550-X
DFW, Texas, USA, Planet Earth, Milkyway Galaxy
Naji
DIB 2015 Mustang GT PP
Nice write up! Another way to remove the tape without pulling the other plastidip, is to pull it while it's still wet.
papinist
papinist
The Italian Pony
Tuscany, Italy
Stefano
Yeah it would be cool, but too much work for me :)
Great tip! I'll remember this :thumbsup:
cgreen5150
cgreen5150
Loomis, CA
2015 GT, Premium, PP, Recaros
Awesome! I was planning on doing this so your write-up was perfect timing. Glad to see what I planned will work.
Cerberus
Los Angeles
2016 Mustang Ecoboost (Magnetic)
Nice job, but I'm a bit confused as to why you decided to do your painting in your engine bay (and thereby risk getting paint elsewhere on the car--even with the trash bag and masking). Why didn't you take the tank elsewhere in the garage, or even out in the yard, to paint it?
papinist
papinist
The Italian Pony
Tuscany, Italy
Stefano
Because to remove completely you need to disconnect all the tubing underneath. I didn't remove them to avoid problems with air entering the pipes.
Osofast
Boston
2018 mustang gt premium
Wondering if you have had any issues with the pastidip holding up?
I did mine and it looked great until I ran the car and the heat from the coolant made the plastidip bubble up almost like it shrank and stretched across the tank rather than lay on the tank.
Weird I have used it in the past with no issues, but not on something with that amount of heat.
Any advice?
GT Nate
2016 Ruby Red Mustang GT Premium
I did mine in 2016 and it still looks new today.
djcodeman
Austin, Tx
2015 GT roush SC
Nice writeup! Will do this next!
MROCGUY
AZ
2016 Mustang GT Premium
rustoleum bedliner?
djcodeman
Austin, Tx
2015 GT roush SC
Came out looking good
