SStormtrooPer
Dark Side
- Aug 17, 2013
- Lafayette, CO
- Jesse
- Single Turbo GenII Coyote Swapped '92 SSP
I am in the middle of swapping out my oil pump gears for the billet variety on my 15/16 crate engine, and I have an issue that has me confused --
I am trying to line up the timing marks on the cam gears, crank gear, and the links on the chain before I remove the chains, but they won't line up. I can get the marks on the chain/gears on the passenger side bank to line up, but not the driver's. When everything is lined up on the pass. side, the driver's side links are in the middle of the chain between the two gears. On a Livernois write-up I read, they said they lined up all the marks before removal, and showed pics.
That said, I can make my own marks on one chain, its not a big deal -- but should I be concerned that these aren't line up from the factory, as in one or more of the cams may be incorrectly timed?
At the factory, would the chain be put on by a robot, or a person?
In the pic you can see where the blue links are -- on the pass. bank they are lined up with the marks on the gears. I have turned the engine over enough times.
