Cobra Guy
I have a roll bar installed so the shoulder belts are not a problem. My question is the attachment points for the lap belt and anti-submarine belts.
I read a previous thread about running the anti-submarine belt through the fold of the seat and attach to clips behind the seat. I tried this by fabricating a couple of clips and bolting them down with the 2 back bolts that connect the seat to the floor. The problem was that when I slide the seat forward for a comfortable driving position the anti-submarine belt is not long enough. Plus I was told this was not a very safe way to attach.
After talking with a few people the suggestion was to attach both the lap and anti-submarine belts to the same point on each side of the seat. I have the Sparco Harness and the eye bolts to attach the belts along with the backup plate to attach under the car if necessary.
My question is has anyone drilled a hole through the floor on both sides of the seat at mid-point and put in these eye bolts? From looking at this real close there does not seem to be a lot of room between the outside of the seat track and the door sills and the inside of the seat track and the console.
I have removed the passenger seat and the OEM belt attachment and I see there maybe an option to use the OEM belt connection point for the inside belts but it looks like the belt attachments will rub pretty good on the side of the console sliding the seat back and forth.
