buggy whip
Don't know if it's been asked before.
Are the front & rear brake hoses "Rubber" or "Braided" ?
Given the massive brakes they chose for these cars it just seems like a shame.Can't it? If you made this kind of decision on half the parts on the car, the cost would blow up. It's not like the stock lines won't last until the car is well out of warranty and really pedal feel so far has been phenomenal. When is good enough not good enough?
The huge brakes actually make them less of a factor, more pad surface area, more piston surface area, means you can get better clamping force with lower hydraulic pressure. It also means much more efficient cooling of the fluid, so expansion of the lines due to heat also becomes less of an issue.Given the massive brakes they chose for these cars it just seems like a shame.
