GT Suspension Torque Numbers
mustang5o
Middle America
2023 Oxford White Mach 1 Handling Pack
I need a diagram of the front like this. Guess I should just order the service manual. I wonder how quickly they get shipped out. I'm hoping to get some work done in less than 10 days before an event.
Here's a page from the Ford service manual.
I need to know which bolts to remove the front hub (and their torque values when putting it back on) so I can swap out the studs for ARP extended studs. I grabbed this picture...are the ones I circled in red with red arrows pointing at them the correct ones. I'm presuming there's a fourth hidden in this pic.
mustang5o
Middle America
I exchanged my front studs without hub removal.
We got them done and almost thought we could do it without hub removal but weren't sure so we pulled the hubs. Ratcheting wrenches helped because the hub nuts were a bit of a pain as well.
aleccolin
VA
www.CarClubVT.com
Colin
2016 GT PP
Here's some more to add to the list, thanks to [MENTION=13829]srf52[/MENTION]
According to the 2015 Mustang GT WSM:
LH and RH engine mount bracket, bolts and stud bolt
Torque : 41 lb.ft (55 Nm)
LH and RH engine mount nut
Torque : 46 lb.ft (63 Nm)
The top transmission-to-engine bolt and stud bolt
Torque : 35 lb.ft (48 Nm)
LH and RH transmission-to-engine bolts
MT82 transmission support insulator and crossmember and the bolts
Torque : 76 lb.ft (103 Nm)
Transmission crossmember to body bolts (x4): 46 lb.ft
Crossmember to insulator nuts (x2): 52 lb.ft
Insulator to transmission bolts (x3): 76 lb.ft
FreePenguin
Ohio
Donald
17 mustang
Thank you. I needed strut tower torque specs
Bumping for others to utilize and not be forgotten
TeeLew
So Cal
Tim
Do we have any specs on driveshaft fasteners? TIA.
TeeLew
So Cal
Tim
Honestly, when you disassemble stuff like this, it generally makes the job easier and better.
guitrflip
Glendale (818)
Jason
2017 Mustang GT Premium
Wow you guys rock! This answered my questions immediately.
Bumping for 2021.
Cheers.
Taylor18GT
Illinois
Taylor
2018 Mustang GT Performance Pack Level 1
This thread was useful when doing my coilover install for the spindle bolts and subrame. I won't lie and say that some of the "other" bolts just got however many ugga duggas my baby impact gave them.
GTIIIL
Encinitas CA
2020 Shelby GT350
I know I’m resurrecting an old thread, but are the original bolts torque to yield from the factory, but the replacement bolts or just a straight torque setting?
Nodster
UK
James
Hello. I've just printed out the S550 Bushings diagram. Amazing thank you. I'll give that to the workshop fitting the springs. But I noticed one of the arrows has no value assigned. Does anyone know what it should be please? Thanks.
mustang5o
Middle America
Now I have a 23 Mach 1 coming. I wonder how many of these are the same? Otherwise I will need to order another service manual CD.
