Dirtleg
BoostCreep
- May 24, 2014
- Cloverdale Va
- Greg
- 15' EB Prem PP, 07' GT (track Car), 01' RC51, 16" S1000XR
So this is a subject I've not found much info on relating to our EB engines.
Sure there are the recall issues from the 2.0 for pulsation dampener issues a few years back but that's not what I'm focused on. At all. In fact I'll just say it right now;
Please lets keep this thread on point in the event there is any interesting discussion here at all. Thanks.:cheers:
So back to my original topic.
While doing some research of our DI fuel system I've found on here and other places some pictures of the cam/pump actuator and also read about fuel pressure consistency problems in specific rpm ranges. I am not sure if it coincides with the 5200-5500 rpm chatter I've seen in the stock dyno charts but my mind can't get away from the idea they may be related. I could be just flat out wrong here and if I am so be it.
Well it's obviously not pump cavitation as it clears up at a higher rpm. So it got me thinking about resonance and at what frequency the fuel, or fuel system became unstable. At this point in my understanding of things my ideas are all theoretical and should not be taken as fact FYI.
As is the case with every component on our cars, the fuel pulse dampener on these engines is a cost vs performance compromise. I'm thinking the simple addition of a displacement based dampener downstream of the fuel pump might smooth out the fuel pressure issues. This would provide a consistent flow for the injectors if it could reduce the resonance effect on the pump. Being that it's displacement based it could even provide extra (stored) fuel in the event of a momentary pressure drop.
So with that said what are other peoples thoughts in this area?
