Ultrakla$$ic
Whoflung Poo
Anybody know what the center bore specs are on the front wheels of our 2015-2016 GT's??? Is it 70.5?????
So a hubcentric spacer needs to be 70.5 mm center bore to fit properly? Correct?Yes the center bore is 70.5
Yes for the spacer to be hub centric it would need to be 70.5. Are you using it on after market wheels or on your stocks?So a hubcentric spacer needs to be 70.5 mm center bore to fit properly? Correct?
Aftermarket. Anything else I should know and thanks for helping me!Yes for the spacer to be hub centric it would need to be 70.5. Are you using it on after market wheels or on your stocks?
If you are going to get the spacers custom made I would find out what the bore size of the wheel is so you can make it hub centric to the wheel as wellAftermarket. Anything else I should know and thanks for helping me!
Gotcha! Didn't think of that!! Thanks a million for the insightful replies!!:cheers:If you are going to get the spacers custom made I would find out what the bore size of the wheel is so you can make it hub centric to the wheel as well
Anytime, if you have anymore questions feel free to ask :cheers:Gotcha! Didn't think of that!! Thanks a million for the insightful replies!!:cheers:
Thanks Paul! Appreciate the info!!!If you use a spacer brotha max size is 5 mm so you get a safe amount of turns.
Welcome brothaThanks Paul! Appreciate the info!!!
You guys are awesome for helping me with all this. :cheers:
