Ford Adjustable Camber Plates
DB83
Granny Shifter
Spain
2017 Mustang GT
Anyone know if the ford adjustable camber plates as the ones that come in the Mach1 and GT500 track pack can be used in regular GT models? Or are the springs on these models completely different?
I'm basically wanting to run these on a set of KW V3 coilovers on my GT if possible.
Smunczen
Atl
Scott
2020 mustang gt pp2
I have them on my 2020 PP2
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
I would assume they are different spring diameters. I say that because camber is plates from Vorshlag or Steeda have different part numbers and product listings for OEM springs and KW coil overs
DB83
DB83
Granny Shifter
Spain
2017 Mustang GT
DB83
DB83
Granny Shifter
Spain
2017 Mustang GT
I think that has more to do with the damper shaft diameter, as the in KW's use the stock upper mount and isolator.
Smunczen
Atl
Scott
2020 mustang gt pp2
Yes reused the oem isolators
Biggsy
MD
Warren
Roger that. thanks
