Emilbadal
Hi everyone,
Recently, I have changed my job and my commute is around 110 miles round trip. After a month in my new job, I noticed a kinda faint whining noise which is mid to high in pitch. I cannot pinpoint it where exactly it's coming from other than it's coming from the back. I was suspecting the wheel bearings going bad , so I decided to do the do some tests. I jacked up the rear, and did the shaking test in nuetral and parking brake disengaged both ways(up Down and side to side). No slack whatsover. I did the spin test and listening to any kind of whirring sound from the bearings, still nothing. The only noise I hear is brake pads on the discs. Since turning the rear wheels in nuetral is very difficult, I turned on the car and put it in gear and let it spin the wheels. Still nothing, other than the brake pad noises. After that I test drove the car suspecting maybe the rear calipers are acting up maybe and they are scarping the pads on rotors, however at highway speeds regardless of me braking or not or steering side to side, the noise stays consistant and doesn't change which tells me that the brakes are not the culprit either. It is perplexing me a bit, because I've never tracked my car and never have done any burnouts or donuts ever. At this point I am only suspecting that it might be my differential, but that also seems premature failure at 26K miles. I'm wondering if anyone has had this kinda issue and could shed some light and provide some guidance.
Thanks in advance
Thanks in advance
