I think I made a couple drivers really angry cause I spent a very long time in stop and go traffic without using the brakes more than a couple times. Problem is that using the brakes is kinda overkill in traffic.Who here does it religiously?
With the car being as loud as it is, and the planned removal of the resonators, I think I'll have to be a bit more mindful of the noise coming from the downshift engine braking. I'd be sorry for the noise, but then again, not sorryI think I made a couple drivers really angry cause I spent a very long time in stop and go traffic without using the brakes more than a couple times. Problem is that using the brakes is kinda overkill in traffic.
Agreed, or clutches.Brake pads are alot cheaper than crankshafts.
And what does this have to do with engine braking?Brake pads are alot cheaper than crankshafts.
Depends what RPM. Keeping it in the 4-6000 rpm is unnecessary wear as well as heat.after the clutch has engaged is engine breaking that bad? I know you wouldn't want to trash the clutch but I engine break quite a bit.
