KrisR
- Mar 24, 2016
- White Bear Lake, MN
- 2015 Mustang Ecoboost PP 50th Premium
Hey all. Got my Lund 93 tune loaded up last night, and got a file from them today with all the PIDs for logging.
Couple things, because I like looking at my logs and knowing what's going on...
How much spark advance are you guys / gals seeing at WOT? My log only shows between -2 to 2 degrees of spark at WOT. At cruise it's typically in the mid-20 range. Both of these seem a lot lower than I'm used to with previous cars (even older power-adder-equipped Mustangs), which usually had around 35-40 degrees at cruise and 14-17 degrees at WOT on pump gas (a little more on E85 typically). Maybe the new stuff just reads differently now?
How do I convert the MAP reading to boost in psi? I'm seeing around 71-72 on the MAP sensor reading at WOT in 4th near the top end. What's that convert to in boost pressure?
Thanks!
Thanks!
