Inthehighdesert
That’s an interesting read. I didn’t have any of that on my before or after the swap and fi. My r either. Out of curiosity did you ever reach out to McLeod? This is one thing you and the op are experiencing that I never have dealt with on literally dozens of manual vehicles. My first instinct would be therea something going on with the pressure plate. A cylinder going bad would generally get chatter but not what you guys are dealing with.
I have the same issue in my 19' 350. After pulls, the stock clutch pushed on my foot back up a lot harder than normal after pressing it. Then sometimes when upshifting right after pulls, the revs would go up by themselves briefly before upshifting. And when staying in gear and cruising right after pulls, it would slip and the car would physically feel like it was stuttering. This would all go away as it cooled down however.
I went in and replaced with a McLeod RXT 1200. After the 1000 mile break in, it did the same thing lol. I had the clutch changed, aluminum flywheel, braided lines, and replaced the stock slave/throw out bearing. But now, the only issue is that after 3 or 4 pulls, the clutch slips while e cruising right after pulls and the revs go up by themselves when upshifting after pulls. This all goes away with a little bit of time and cooling.
I spoke to other mustang guys around my area and they say it sounds normal and they experience it too, some to a smaller degree than others.
