Competition Orange
- Aug 25, 2015
- Columbus, Ohio
- 2017 GT350
I bought the btbr kit and spent way too long installing it. I used the outside lower grill location and it worked great, very secure. Backing plates mounted up (I will say that the angle of the connection is quite verticle) and everything trimmed for routing hose.
I started with the drivers side and went on the front side of everything. Did not route under control arms and back over sways as recommended as the hose would basically stick 3" under the car and there just isn't enough room.
Issue 1. At full lock (front of tire inward) the tire is fully against the hose. Seems the hose is too large? The car is on jack stands, so will being at drive height eliminate this? Seems doubtful.
Issue 2. About halfway through the turn, the hose it's the inner wheel barrel. I think I can solve this one by trimming the hose slightly shorter but IMO the angle of the connector on the backing plates is too vertical.
Any pics or suggestions on how to route these without rubbing?
PS I'll get pics tonight.
