TheLion
Getting back to the questions above, there is debate on the control mechanism of the BOV. It's well understood that you need to use Boost and Vacuum to physically operate the valve properly no matter who makes it to prevent fluttering and leak.The design of this blow off valve itself is very similar to something like our Focus ST one. The biggest difference would be the Mustang specific bolt pattern, depth, and spring pressure.
The debate is in the control mechanism. A pneumatic pressure switch, which is the traditional method, or the ECU controlled manifold. While both are powered by pneumatic, one method is fixed, so you set it and forget it, it works the same every time. The other method, ECU control method as with the factory and Boomba architectures, allow versatility, the ECU can change the parameters under which it operates the valve as opposed to being fixed.
What is the advantage of an ECU controlled valve as opposed to a traditionally fixed valve?
