BMR CB006 4pt and CB007 2pt Front Subframe Chassis Braces - A10 Transmission Compatible :)
Status
Not open for further replies.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Just want to let you all know that we redesigned our braces (last year) to work properly with the A10 trans equipped 2018+ Mustangs.
Instead of adding parts to the kit to shim it for clearance, we revised our designs to fit the cars properly.
Thanks to all of you who support our operation and purpose!
:thumbsup:
BMR Tech
BMR Tech
Tampa, FL
Dion
Forgot to add, the revision to the CB006 also allows fitment for GT350s and all V8 equipped cars with GT350 / 18+ composite oil pans .
RichBrew
GA
Scott
2019 Velocity Blue EBPP
I assume this applies to the 18+ Ecoboost w/A10 also? I tried installing the Steeda 4-point brace, but it contacts the transmission, which causes problems. They have a 2 point brace made specifically for the EB w/A10, but no 4 point, and no plans to make one. I'm hoping this might be a viable option.
Crowd Hunter
Tennessee
$hitbox
I ordered a CB006 from Amazon last night. I have not received it yet, but after reading this, I am worried that it's the old style and won't fit my 2019. This will be my first experience with BMR. I have to say that revising the part and not changing the name seems like a mistake. Hopefully I won't have to return it.
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
Well if its drop shipped form BMR then I expect it to the be the redesign. You should be fine.
Anytime BMR updates a products and you happen to get the previous version, they have always been good with sending you the updated version. Having different names for every revision would get confusing.
Danmg202
Oregon
2018 mustang gt- 401a - PP1
Just installed the newer style cb006 on my a10 PP 2018. There is next to zero clearance between it and the oil lines. I placed a little dynamat on top of the brace for the moment but next time I lift it I'll see if I can move the lines or wrap them. Feels great on the car anyhow.
Emilbadal
Socal
Emil
2016 V6 Auto DIB
@BMR Tech Guess what guys! The revised 4 point CB006 also fits V6 mustangs as well ;)
Crowd Hunter
Tennessee
$hitbox
Got the part yesterday and installed it in 30 minutes. Fits like a glove! It is the new version with the cutout for the oil-pan plug.
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Will this fit and eco? I understand that the 18eco with the A10 sits lower than the ft with the A10
Crowd Hunter
Tennessee
$hitbox
Not sure. Mine is a 2019 V8 MT and there was a ton of clearance.
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
RichBrew
GA
Scott
Yes, they redesigned to fit the A10. Not knowing it wouldn’t work, I first tried the Steeda brace, but it contacted the transmission, and transmitted all engine vibration into the chassis, that was a nightmare. I droveit less than 3 minutes before doing a U-turn to take it off. I then ordered the BMR brace, and installed it on my 2019 EB A10, and it works like a champ. Love how it tightened up the front end.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I wish you offered both versions, as I believe the cutout in the center of the brace weakens it. I boxed mine in after running it as delivered and I can tell a difference. Better boxed.
Exhausted
Oklahoma City
Michael
Mustang GT PP1 A10
I did have to push on my transmission lines and put a hose around them as they were hitting and rubbing the brace
Status
